http://www.boostcruising.com/forums/index.php?showtopic=709419&st=0
We eat delicious iced dairy products. Boostcruising tough dream boats try to get a mate to beat up photographers at a meet. I know where I'd rather be thumbsup.gif
One of the many pics of the Japan aftermath.
Not sure what the car was, but I wouldn't mind the brakes of it.
Will have to spend some time perusing japan auctions in the upcoming months :P
I reckon its a R32, tow hook and fuel tank look about right
Morning Mangs,
TFIF! Weekend soon, then a 2 day week, then melbs for the GP. I am excite :D.
Then another 2 day week when I get back :).
Not a bad idea.
I think that was a record trip for me at baskins tonight.
Silly Squid.
I like the new girl... but hopefully Morgan is back next week.
Thanks again to Scott for sorting out my ECU :)
Looks like that topic was deleted :(. Fill us in, brother.
Last week some dumb bimbo ran a guys foot over at Harrys. Boost did what they do best and started an Internet fight over it with some people white knighting the girl and others saying she was a useless twat who shouldn't be in a car. A random poster said everyone was too much of a pussy to say any of that shit in real life and one of the photographers called him out and said he was as much an e-thug as any one else.
Following week (last night) the photographer is confronted and almost bashed by the posters mate, proving he (the poster the photographer gave shot to on the forum) is both scum and a pussy. BC has another little forum war.
Lol at boost story. Wish I was there last night for the lulz.
I got given a blackberry to use as a work phone. I hate blackberries.
Mmmmmm haven't driven the skyline in a week or so. Drove it last night....... f**k it's nice hahahaha
Could have been worse: They could have given you an iPhail.
Meow
Sup Babe
That is why we don't sell them ;)
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
