4 months of skyline ownership and yet to get any attention from the boys in blue. I feel unloved. Maybe this is a sign i need to take my exhaust off or something to attract some attention.
edit: to be fair though, i don't daily drive it.
edit edit: and of course i didn't realise there was another page of stuff here
Edited by sneakey pete
Just means you haven't done enough to it.
Start forking out some dosh on upgrades
I dunno about that, still never been pulled over other than at RBT.
I generally only get pulled over when I deserve it.
Except for that one time, when they pulled me over because I honked the horn at someone who didn't give way to me at a roundabout...
Eggggggzackery, Where you drive, when you drive and How you drive are the difference between getting pulled over non stop and barely getting a glance
PRO TIP: Dont drive down blunder road on a weekday during business hours
I never get pulled over.
You just get tonnes of free photos in the mail
Hello ya bunch of skirts.
After some opinions on highflows. I have the oportunity to buy a secondhand GCG highflow with apparently only 5000km's for $1200 delivered. This could be a winner, but the thought over getting a Hypergear jobby for less and is 'new' is appealing.
The only 'benifit' the GCG unit has is that it used a BB CHRA unlike the Hypergear and that you can use the standard oil feed line. The downside of the GCG is that it is a R33 item (Stagea uses R34 turbro) and I have seen a few of them requiring a rebuild after 20thousand kms.
I think I'm leaning towards the Hypergear as it also comes with a 60k warranty if installed correctly....
Thoughts? discuss.
http://img27.imageshack.us/img27/2397/sdc11758v.jpg
http://img810.imageshack.us/img810/5915/sdc11765.jpg
http://img269.imageshack.us/img269/7353/sdc11760.jpg
http://img263.imageshack.us/img263/3619/sdc11762.jpg
Edited by SABBAi
