Hmmmm thats weird because we were asked last week to organise a cruise by the owner of nando's for this Anzac day .... with approval from centre management (the owner of nandos drives a RX7 series 8) :
lol good luck on the cruise :) we did a small cruise anzac day last yr. didnt see a single cop the whole drive but forgot to plan ahead...and got stuck at 3 lots of anzac parades.
most of which we found our way around. 1 we had to wait out (not too bad). but having said that we only had 7 cars
*carseldine was fine on thursday night...other than it being the start of the uber long weekend and very little parking to be found anywhere. (didnt head underneath). and it took me almost 10 mins to get off the road and into a park
Edited by boiracer
^^^ yeah cheers, fingers crossed should be a good night....!
SAU guys are also welcome obviously! (i'll be taking my skyline to the cruise)....
Its usually the bonnet release lever that snaps off the fuse box. Is the fuse box where the bonnet release mounts to it damaged at all? Its a common problem with BA/BF falcons for them to snap. I have changed a few of the bonnet releases over. You need to change the whole cable over with it. Absolute prick of a job to do.
Yep the latch has snapped off the fuse box, looks like the mounts are destroyed as well. A friend of mine took his to ford and got it replaced under warranty, they pulled the entire fuse box out and swapped it with one that had metal on the bonnet release instead of plastic like mine.
Do you know if I would be able to get a bf fuse box and swap em over easily or is it a bitch of a job?
Fuse box is pretty easy to do from what i remember. The only pain in the arse bit is getting the wire bit of the bonnet release to pull through. When removing it you will need to drop the wheel arch liner out makes the job a bit easier. If you have mud flaps you will have great troubles getting the clips out. You shouldn't have any troubles getting a fusebox. I am not 100% sure but i think BA/BF fuse boxes are the same
i didnt read the 7pm bit....so night should be fine for missing parades i guess....lol. :whistling:
*hopefully i can make it......all depends how sober i am from the night before
Edited by boiracer
Anzac day woollies is closed... so i wouldn't imagine a problem...
I'm doing up a pro/con list of FF vs FR. Anyone care to contribute? If I do it on my own I might be subconciously too bias.
What do you want to know?
What point of view are you looking at the question from? Driver? Manufacturer? Mechanical issues/reliability? Why no AWD being considered?
For example, a major pro of FF cars is the lower cost of production. This isn't much of a bonus to a driver however (unless you count purchase price into the enjoyment factor.)
In the end it comes down to your traction circle and the physical limits you can take your friction surfaces to (tyres).
Carroll Smith Has a fairly good entry level explanation of this in one of his books, tune to win I think is the one.
Dubstep fiends - about a year ago when I played CSS alot, there was a song that would come on and it had a part of summer heights high in it - "how is it ok for you to bully ben?" any ideas on song name?
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
