I'd be solidly up shit creek without my phone. All my work contacts, staff phone numbers, friends, family etc are in the phone. I couldn't even tell you the phone number of the pub off of the top of my head, I'd have to look it up. I have about three numbers memorised and they are all family. My last girl friend cracked the shits with me because I couldn't remember her phone number.
Anyone got a spare telstra compatible phone they could lend me?
I had 2 of them till some shitcarnt came in to the house one night and flogged them
Morning Mangs,
Sucks about your phone Martin. I'm useless without my phone. Glorious weather today lol glad I've got the car. I think I'm paranoid about the car at the moment but I keep hearing weird noises and the turbos sound a lot louder than normal. More pronounced whistle coming from them. Definitely need to get it booked in with Dan ASAP.
I swear to god the universe has it in for me right now. Only day off work this week and I'm going to work...
After work I get to move house (finally) and of course it's raining.
However, ribs and meeting tonight make me happy! See you mangs there!
Holla
German Club soon.
Morning Mangs,
Thanks Noel!
@Col: Big end for sure.
Do turbos whistle louder when they're on the way out?
Holla
Olla
Morning Mangs,
Do you think paranoid people are following you also??
P.S. knock, knock.....
who's there?
BIG END!
Ribs, beer and Ike Creams. nice.
Got your phone martin. cya after the exec meeting.
I read that as I got your phone Martian.
Morning Mangs,
Thanks Noel!
/\ This man, he speaketh the truth.
We can play the sound game again. What sort of noise does it make? Can you describe it in letters and words that make no sense?
Sqeak, whistle, scrape, whine, etc?
Does it sound like one of Kenworth's finest at idle? If so, your trunk monkey fitted a HX35 with adjustable nozzle, while you were sleeping...in Seattle.
P.S. See what I did there :ph34r:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
