Mangs
Day 1 of quitting smoking. Can already tell it's going to be hard.
Does anyone know who owns the black 34 gtt around albany creekish area? Seen it a few times, has an SAU sticker on the rear quarter. Would like to know what kit is on it
Morning Mangs,
Keen for dinner tonight. @Boz: Whats the dress code for the Fox on a Wed night?
Also, I run 595-SS as well. Rain = shit. All I have to do is look at the throttle and it breaks loose.
Next time try Khumo KU31s. They are legit *finger snap*
I'll be going back to them once I burn though these SS's.
Mangs
If you don't quit, you're a fairy. Do it, you skirt.
/encouragement
dang, i was totally going to rock my high vis :(
cheers broo
Thats a bugga Marty, You wont be able to show off your new high vis mankini and steel cap thongs. :teehee:
Thongs are OK; I'll just tell them the steel caps are made of carbon fibre. Should get away with it.
I'll rock the non high vis purple mankini instead.
No Cassie at Powerlink. Disappoint :(
McFly, tell them to pick their act up!
Maybe she is avoiding you? :P
I have never had a problem with the SS. I have to provoke the car to make it break traction..then 4wd come along and sorts it out
Alvin magically makes 800 hp when it rains :thumbsup:.
I am not saying they are a bad tyre by any means. OK, I did say that, but only in the wet. Even then, for what you pay for them, they are a damn good tyre.
But I can get Khumo KU31s for the same price (option 1), and they are a little bit better in the dry, and worlds better in the wet. So to me, that makes the SS's shizenhouzen :P
RSRs on the other hand are f*cking magic. I want to marry them, and have their babies.
Liquid Horsepower :thumbsup:
Hahaha so does Susan :D
A match made in heaven perhaps? :P
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
