Good luck! Did it snap? :(
I meant that I'm hoping that I'm not the one who causes the valves to get munched up after I've chnaged the bellt :P it hasn't snapped, but it's overdue and I won't be at all surprised if it's skipped a tooth or two. My car is running like absolute shite lately.
Speaking of which... anyone seen or know of any good deals for air/intake/engine hoses/lines? Some of mine really need replacing. Going to change my oil pump next service, and maybe my fuel pump.
Edited by Isola
If only our IT people felt the same way!
There's probably a reason they are stuck at 1st level support in a govt organisation :P.
I wouldn't cross fingers, it makes it hard to put bolts in
I normally just use my mouth...
Ahh good. You'll be right, it's not a particularly difficult job. There's marks on the cam gears and the plate behind em to help you get it all lined up right.
I bought like a 10m roll of fuel hose off ebay to redo all my fuel lines. It was good quality sh*t and way cheaper than buying it from a local rip off merchant.
All the specialised intake/engine type ones I got straight from nissan (it helps to have the part numbers). The majority of them are pretty reasonably priced, but it does add up if you do a lot of them. You could also look at the silicon kits off ebay, but I don't know if they do them for a 20. They didn't do em for a 25 when I looked.
Disappointing form tonight, two events in two nights too much for you?
Good news though, my phone has been shipped :)
drove past around 9pm, nobody to be seen
figured a decision was made the night before to give it a miss this week
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
