Good luck! Did it snap? :(
I meant that I'm hoping that I'm not the one who causes the valves to get munched up after I've chnaged the bellt :P it hasn't snapped, but it's overdue and I won't be at all surprised if it's skipped a tooth or two. My car is running like absolute shite lately.
Speaking of which... anyone seen or know of any good deals for air/intake/engine hoses/lines? Some of mine really need replacing. Going to change my oil pump next service, and maybe my fuel pump.
Edited by Isola
If only our IT people felt the same way!
There's probably a reason they are stuck at 1st level support in a govt organisation :P.
I wouldn't cross fingers, it makes it hard to put bolts in
I normally just use my mouth...
Ahh good. You'll be right, it's not a particularly difficult job. There's marks on the cam gears and the plate behind em to help you get it all lined up right.
I bought like a 10m roll of fuel hose off ebay to redo all my fuel lines. It was good quality sh*t and way cheaper than buying it from a local rip off merchant.
All the specialised intake/engine type ones I got straight from nissan (it helps to have the part numbers). The majority of them are pretty reasonably priced, but it does add up if you do a lot of them. You could also look at the silicon kits off ebay, but I don't know if they do them for a 20. They didn't do em for a 25 when I looked.
Disappointing form tonight, two events in two nights too much for you?
Good news though, my phone has been shipped :)
drove past around 9pm, nobody to be seen
figured a decision was made the night before to give it a miss this week
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
