Erm... they usually go till around 4 or so... presumably will finish and then happy laps will start not long after.
They sell food there but it is crap and expensive. I usually buy it anyway though :P. You can bring your own if you want though. Suggest you bring a chair as well...
Didn't know if the canteen thingy would be open. I don't have a chair :(
drop past here on the way. I'll leave my fold up one outside. (I want it back though.)
I'd say a small hole in a radiator hose is a win for the club as far as damage goes. Much better than two cara going home on the back of tow trucks as happened last time :(
We'll have to coin the phrase
I've done a Boz
if any one of us busts anything to do with our cooling systems.... ;)
We'll have to coin the phrase "I've done a Boz" if any one of us busts anything to do with our cooling systems.... ;)
I did a Boz once:
Did an oil change on the chair. All the vitals are very healthy. Lovin it. :thumbsup:
WINNING.
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
