There is no way I am going to go and eat icecream, outside, in single figure temps. That to me defines silly.
^^Skirt.
It hasn't even hit single digits on the big a*se thermometer there yet anyway.
So uber turbo has been paid for and will be built this week. 350hp+ atw in a sub 1100kg car.... Bring it!
I hope I can make that much in my 32 when it's finished. I picked up my block from Chiltons this morning, just gotta put it all together now and port the head. I'm hoping my 4 year old $100 225/50/16 tornados will be adequate for traction
Thats pretty exciting!
Those tyres should hold.....at idle
Morning Mangs,
TFIF.
Ikes Cream meet was good, Andy is a skirt - it only got down to 11 degrees.
Drama towards the end as 2-bob, 5-quid, and douche got reversed into in the carpark as they were leaving. :(. Hope insurance doesn't give you any trouble, let us know if you need witnesses.
Final thought: Hail to the King, baby!
WTF are you on or about on both counts Smitz ?
Count the first: On or about the 9th of June, 2011, one twocents, while driving a car owned by his girlfriend, five-quid, and with overly exciteable passanger the mighty douche on board, was struck in the front right quarter panel and drivers side door by a silver Honda CR-V who decided to reverse straight put into them. Details were swapped, quarter panel was bent to allow door to open and the mighty douche continued to dance around in excitement over his purchase of an auto loading pipe.
Count the second: After a development time longer than the time between "we will have a man on the moon by the end of the decade" and "That's one small step for man..." Duke Nukem Forever is finally coming out. Nerds everywhere have had a collective orgasim.
Seriously, Duke forever has taken longer to release than the foundation of the Apollo missions to success with Apollo 11. The Beatles formed, recorded all their albums and broke up in less time than this game has been in development. While this game has been in development multiple wars have broken out and a few have ended. Britney Spears' entire career fits inside the development window of this game. It took them less time to build the channel tunnel than this game. It better be one genre defining game is all I can say...
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
