Yeah he seems like a pretty likable guy.
1 year today mangs since I got my license back.
Are you fkn serious!? Wow that year has gone past scary fast.
Apparently there are no R31 right side handbrake cables in Australia and I have to order one from Japan :rant:
Anyone know around how much it would cost to get one made up at some place?
@Joel: Sounds like BS. HR31s use a different handbrake cable mechanism anyway.
Have a bit of a search on 31 club - i think theres some info on there somewhere on getting them custom made.
Also try rapeco, pretty sure they sold them last time I checked, but dearer than nissan :(.
RE: Redzomboobies, etc. I will comment when not at work...
he wants blue. std small nissan bulbs on the back ot it. send me a text 0407102839 and I will send you the rear of that cluster.
i see you got stuck in Geebung this morning...
I had a customer that saw the whole thing happen sitting at the barrier on Newman rd on his way to work...
Needless to say he didn't end up staying at work for long, he was violently ill...
Yeah. It significantly lowered my contempt for the little german weasel.
I saw an interview with him before the race on the bbc and yeah, he came across as allright.
In the podium press conferences though he's farkin annoying. And there's that f*cking finger... :devil:
lost any points?
Redzomboobies caused much fappage. I can has moar?
Def need moar redzomboobies!
look at the speedo.. they are not meant to go that fast.
I can make a speedo go that fast... on my bench.
I must have just missed all that traffic on the way in to work. Heard about it all when I got in. N.G. :(
traumatised I bet. wife works for QR and told me she was stuck at zillmere. thats how I found out.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
