think the whole MEH thing has taken over the country. certainly stops phones ringing..
Pull the plug then you don't have to rely on the Meh factor
white on white is strictly for men who's faces enjoy the company of other mens wangs
Colin, I would be worrying about these things before changing how it looks
As if choose gold wheels over white when you have a white car.
It's all about the contrast mang. White on white is boring as batshit. The advantage of a white car is any colour wheel looks good with white.
Yeah there are a lot of things that are ahead of pretty stuff at the moment. One day mangs...
