Particularly now that the general instability has gone (well, give it a few weeks for this to blow over) i think you'll find gold is actually a pretty bad option. Though you've done well in the last few years, on average it doesn't seem to go up as much as the share market does, i think.Or something. i'm not a professional.
when the share market goes bad gold goes good
Morning Mangs,
Hey, McFly!..
...yeah
Looks good!
Wheels don't look multistud though
Me likey!
That's what she said.
Throw in a cat with helmet cam. :thumbsup:
LOL! Don't have a cat, or that would have been an awesome plan
Moaning ho's.
Might take apart the cross over pipe today and replace the valley cover.
That or I might spend all day on the couch.
Ah, the agony of choice. What happened with those 2 jobs you got offered?
R34 is apparently a bit harder due to TCS, etc.
Bored.
Need nets, saw my old batting coach. Need to practice this new stance and 'trigger movements' that will apparently get me back on track fast.
Will you be around this weekend?
Batting coach. Need one of those.
Yeah should be.
I found mine from back in the day. Had a quick catch up.
Cool I will be in contact and see if we can organise somthing. I will see what Gerv is up to as well.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
