Morning Mangs,
She's in engineering for the next couple of months.
Damn :(. I don't want to know how you always know what she's doing, you creepy stalker.
She definitely needs a rape whistle.
Agreed. No wait, don't give her one of those...
Martin, sounds like you haven't had a bit of a with this chick before nyaanyaa.gif
I read it a few times, but I still have no idea what you are trying to say...
I will assume you are giving me sh*t though, and I put it to you sir, that you sucked off a horse
:P
God-like abilities.
That's what she said.
Speaking of the ladies... do any turn up for icecream on thursday?
Was trying to get my misses to come with but I'm having a bit of difficulties on the persuasion
try this :domokun: repeat until she agrees to attend.
Will the kitchen sink fit in the skyline?
Lets put it this way... not many come more than once :P
A fair point, good sir.
I beleive both Natalies have also clocked in more than one appearance, and Alyssa (John's missus) back in the day.
But that would be about it...
WTB: a decent frigging immune system. eyes watering, nose is running like a tap
my mrs likes ice cream
Might show up one day if we ever have a street car.
Showing up for ikes cream doesn't mean showing up for it in a skyline...
Or you could just rock up in your thing anyway.
Edited by sneakey pete
Too much of that crap going around at the moment... Some pretty bad stuff. GL mate
Do it. You skirt.
Anna has showed up twice at least
I thought it was only once, but I'll believe you. Twice ey? That's gotta be about as many times as you've shown up :P
Hey dudes. I'll be coming to ikes reem tomorrow night hopefully. Richie, tell your other half that if she wants ice cream this week, she can get it herself lol. Remember, BUTTERSCOTCH!
You gotta check out my new headlights too! Polished them. omfg. *fap fap fap fap*
I should hopefully be there with one of my trademark short but sweet appearances.
Might even get some ice cream instead of pringles and dr pepper this time
Well at the moment showing up for ice cream would mean havIng to drive a Patrol an hour each way. Driving a Patrol for that amount of time without a track day in the middle is not something that any human should ever be subjected to.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
