Split into 2 posts because SAU is sh*t, Race 2 and 3:
I can't watch them at work so I can't see if there's anythign wrong with them, or how much quality utube has sucked out of them. They lost a little bit of quality when re-encoding them to a sane size for upload, but not too much.
Camera is aimed too low on the first vid (my bad), and the sound stuffed up on one of them for some reason.
Most interesting bits are probably my killer first half lap in race 1 and Ben being a sh*t bloke in race 2.
Mangs
Shit weekend was shit
Next one is bound to be the same as I will be in Bundy.
Go karting looked fun. Pissed off I missed out on all the festivities.
haha looks like a bit of fun @ gokarts... nice laps Martin
Was good fun. Laps were OK, Joel was on fire though.
Mangs
Sh*t weekend was sh*t
Sorry to hear mang :(
We should do German club again soon
Morning Mangs,
My vid of happy laps is up, check the event threads.
Ace McFly. haha
That's what she said.
Time to get off the PC to take my 34 in for it's 100km service... $1000 ggoonnneee
Man, how shiny is your bonnet :P
Fark that silver 34 took off @ 1:20 (Also noticed the mute here :D)
Man, that is FUNNY shit @ 10:00 - how fast does Noel fly past lol.
Haha... man, I laughed at all the mutes :D:D:D:D hahaha
Well worth the watch of this vid :D A few good laughs in this one.
I noticed the video didn't work to will being called remotely. The video was much smoother directly off the youtube site:
My whole car is shiny :). Actually, she's pretty filthy ATM. Needs a wash, stat!
Single pegger of doom. He should do powercruise :P
Man, that is FUNNY sh*t @ 10:00 - how fast does Noel fly past lol.
I reckon hey, it was as if I was standing still!
I was suprised I didn't have anything to say when the white 32 lost it. He was the lucky one I guess :P
Glad someone got some entertainment out of it at least :)
Interesting. I blame SAU :P
Mangs.
Tuesday is hectik like skidz.
Out.
well my days are not so hectik anymore lol.
Job hunting sucks azz
why cant i win gold lotto!
time out for me whilst chasing an electrical gremlin in a funky colored car..
(dan I think I worked it out.)
kiwi,
what happened?
kiwi,
what happened?
Had enough of getting treated like shit. plus im wanting to spend more time with kids.
it is dead quiet in the car sales game atm and when that happens it is always the sales peoples fault lol.
So if any of you good sau people know of any jobs going please let me know lol.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
