Deus Ex Trivia:
During sections of the game where the New York skyline is visible in the background, the two towers of the World Trade Center are noticeably missing; the real towers were destroyed a year after the game was released. Harvey Smith has explained that due to texture memory limitations, the portion of the skyline with the twin towers exists in the game's data files but had to be left out of the final game, with the other half mirrored in place of it. According to Smith, during the game's development, the developers justified the lack of the towers by stating that terrorists had destroyed the World Trade Center earlier in the game's storyline.
Mind. Blown.
Monday on 4 hours sleep no less :(
I'm actually not doing too bad though. Small win.
I had the same but due to unemployment it doesnt matter lol
Morning Mangs,
Considering buying a pair of SSDs... someone talk me out of it
http://en.wikipedia.org/wiki/SSDS
a pair of them? but you drive a 31? surely not necessary
FAT
Don't get one.
I remain unconvinced...
I'm a target out there bro
Yeah man, a pair of Super Star Destroyers would rule!
Also: won't be able to make it to ze german club, sorry.... aaand not sure if I'll make it to BR now either. Stupid 34... might need new coil packs.
Edited by GTTG
is dave referring to the FAT hard drive format?
Martin you need SSD's or else there will be no more room on the media harddrives
:thumbsup:
I don't think I have the garage space though :(
Who uses FAT any more?
I'll probably buy a 2TB drive for $78 either way...
German club? You guys get moving to german music?
Hells yes, rock the lederhosen and dance to those german beats. Ever been to oktoberfest? :P
Seriously though, its a club but not a night club. You get smashed on awesome german beer and eat awesome german food. Tis good.
Hells yes, rock the lederhosen and dance to those german beats. Ever been to oktoberfest?:P
Ah haha. I was reading some of the past pages... was away for a bit... see its more of a foodie place than 'clubbing' haha.
I been to one in Adelaide, can't remember the name but it is pretty popular place there. Man the salty foods = easy to down beers :D
And ze sausage is leet... as in not 'thats what she said' sausage :P
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
