my dad will buy this....hes obsessed with turning off that little LED on any appliance....even if it means loosing all settings etc.......:domokun:
Morning Mangs,
TFIT.
Northies are coming to visit tonight, so lets try not to park in the 15 minute car parks.
I just had to laugh at the marketing hype. It's an "ON/OFF" button - pretty sure monitors had them in the 90s.
German club is next week, not tonight :thumbsup:
ignition signal wouldn't be AFM I don't think, it could be coil packs yeah, or maybe a loom issue?
coil pack loom, have seen this exact issue in r34s a few times now.
I may be there this evening. Shall see how the energy reserves go. Have been getting 2-3 hours of sleep a night this week due to teething, so may well be napping.
LOL @ Samsung:
AN ON/OFF SWITCH!! AN AMAZING 0 WATTS!! WOW
Though that made me curious as to what a monitor actually draws.
This is an old dell 19" LCD under normal operation:
~36W
Press the power button on the front (same thing that is on every monitor these days) and it goes to this
0W
That could still be an immeasurably low current. But it's as good as ZERO.
Hard off makes no difference, unless your a douchebag ecomentalist.
Not sure what the issue was :) Chris is sorting it out and will no doubt let me know.
All I know is that there was a 2V power draw when the car was turned off. When we pulled the fuse for the GPS/Stero/LCD screen the draw disappeared. Power drain was killing my battery.
You need better equipment Dave (that's what she said)
Yeah but I CBF setting it up.
I just happened to have a Class 0.2 meter on the bench this morning, exactely the same meter that power stations use, things just dont get any more accurate. Only way to make that more accurate would be to use a really small CT and wrap the wire through multiple times.
I'd be interested to see how much a tv uses on standby...
varies wildly. Our Panasonic Plasma is meant to use .4 watts, it was actually using 22 and around 250 on average when going. A friends Samsung LED was using 178 watts and averaging around 220 when running! Needless to say it get turned off at the wall now.
We recently unplugged our bar fridge, changed some light bulbs, started turning the TV and computer and surround sound ect off at the wall and set the hot water system a bit lower and our power bill went down from around $600 per quarter to about $250. Anything with a transformer will be leaking power so switch those suckers off at the wall and save money!
thanks again for the hospitalities last night guys :thumbsup:, was a nice drive back too. heading out past the towong cemetary and up No. 5 beats the hell out of driving up the main road and down the ICB, milton road etc.
and wholy crap 600 dollar power bill?? geebus that sounds a bit painful. and a good effort to knock it down to 250's
Hey guys
How was ice-cream :D ?
Thinking about taking my car back to the mechanic to check out this sound which wasn't there before 100km service, and now it is. But before I do, thought I'd make sure I'm not just being a picky bastard and see if you guys think this is acceptable/normal.
http://mezmamedia.co...kyline_sound_1/
Edit: need to wait a good 10 or 15 seconds around there.
Edited by wilorichie
Morning Mangs,
TFIF.
Welcome! Thanks for coming.
Yeah thats the way I go.
Hey guys
Ikes Cream was good!
Will listen to your noise at home, if I remember :P
Hey guys
Sounds like it has something to do with timing belt/pulley area. mine has a sound like rubbing under 2000tpm from cam cover but it isnt rubbing. been there for 18months lol
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
