how much killer wasps does a supercharged bug motor make?
It varies a lot. Depends on how much you change the compression & timing and what charger/inlet/exhaust etc. Seen a couple close to the 150HP mark though.
Edited by Isola
All of which (especially the jetski) are water cooled? :P
arhhh yes, i now see your point... very true...
although im not sure about the Lexus, when you pop the hood all i see is a massive plastic cover...
so who knows whats going on under there, probably a big Japanese mouse on a wheel...?
also, you didn't tell me you were paying :P
also, there are laws that prevent that engine fitting.
Now you're just getting carried away :P
slight difference in air temperature/volume/density that cools that one :P
its a 41L just a lazy 2500 cubes lol
that will fit yeah?
That's bigger than the car!
The combined bore sizes are bigger than the length of the car ffs!
So? The point is that 150HP is not enough. And being air cooled is no excuse :P
Isn't that the one that caused most of the b29's to crash and explode in flames?
Probably. They should have used a Merlin.
It's plenty enough for a car and engine that size.
You wanna buy me a Porsche engine and pay for the conversion and mod plating, be my guest. Otherwise, direct bolt in FTW :P
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
    • What!? US law does not apply to the rest of the world!!!
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
