sooo how much is it exactly??? or is it just 20 bucks for a day?
If you stay for less than 3 hours it is free. 4hrs i thinks 3$up to $20 for the full day.
a likely story
You saw the proof, it was 11am and there was a 4 hour enduro just finishing, therefore was up at 7am, no one else was awake so i chilled back in bed with some music on
Dan, when did Nat move to Brisbane?
about 8 months ago, long time no see john, you should come around to our house of awesome sometime
Successful afternoon was successful.
Dropped half shafts off to be rebuilt.
Dropped flywheel off to be machined.
Got HDMI and optical cables for HT setup.
Bi-winning.
Bi-winning.
+New clutch ordered and paid for. Tiger blood.
Bi-winning.
:thumbsup: sounds productive... wanna come finish up and install my intercooler setup for me one arvo??
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
    • My mechanic installed all the parts and then got it tuned which i think is around the corner from him
