Sounds a bit harsh reading that back but having the day off does nothing for the guy or his family. If they wanted to show respect or help out they should have worked and donated an hour or 2 of their pay to the family to help them out. But like I said they're just looking for another day off after the melbourne cup.
Agree 100%. They loose a days pay, may as well organise it so they work and get paid 75% and the other 25% goes to the family. Would be worth at least several months pay to the family. Much better way to show respect.
When I was in my teens I worked for my dad as a sparky's apprentice. I had the weird position if seeing both the union and the employee sides of any dispute, made me dislike how unions operate, but I admire why they are trying to fight the good fight.
unions and lawyers, all tarred with the same brush. They would have you believe they are working for you but the pricks have their own agendas,
Do not believe the lies:
This clutch will not install itself, no matter how much encouragement you give it :(
mine has this same pic on the back......still sitting in the shelf downstairs.
Morning Mangs,
Have to work late tonight :(, so may be late for ike's cream.
When are you ever on time?
Guys ended up going back to work at 9:30 this morning after the union f**ked around for 3 hours lol.
haha no i wont but there is alot of helpful hints for other areas of your 'romantic' life!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
