there is a good carwash at greenslops on Logan Road
I've have always been meaning to check that place out. Thought it wasn't self serve though?
Edited by sneakey pete
there is both a auto wash and 3 self serve bays
Front yard mechanic pro tip: Check to see if the Oring comes off the old oil filter before you put the new one on.
In other news, there's further developments to having a 26 powered veehick-le in my g-raj .
BAAAAHAHAHAHAHAHAHAHA!!!
also: woot! :bunny:
If you can get to my place at around 8:45 that'd be grand, because I won't have to take you home afterwards :). I probably have to do some work in the afternoon (from home) so if I only have to go home from lakeside (not via aspley) we'll be able to stay at SCC longer ;)
Sounds fair :)
Andy where is the one at Greenslopes?
Andy here cbf logging Anna out, it is on Logan road a k or two towards Mt Gravatt from where the Baskins is.
hello all.
Joel, I saw a little black Barina yesterday with they hot blond chick driving it. The Number plates were [2CENTS]. Didn't think fast enough to get you a pic.
think I might call it a day shortly
Got MW3 on the day it came out, and have hardly played it.
Personally think it's a bucket of shit. Lag is attrocious, and the maps are terrible.
BF3 doesn't look much better either. Might get Skyrim or Dead Island instead...
