RE: Games - I bought BF3 the day it came out, played BF2 and had high hopes for it. After I finally got it to install I think it's pretty good, I haven't really played to much of it but I think I'm close to the end now. I think last mission I did was where the main bad dude died on the plane after you rescue him.
There's single player in BF3? Why bother...
does this offer include the sexf as part/whole trade
or possibly mention of used inner bike tubes?
Maybe...
Morning Mangs, TFIF. Although I have to work late again, which sucks :(
Will trade 1x xbox controller, gears of war (no case), AMD 3000+ cpu (no heatsink) and $40 cash.
In Flames just announced for Soundwave 2012. Possibly my most loved band in the world. Here's a video so everyone else can like them too.
I so need to get some tickets.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
