can any of you guys draw ??
as in engineering drawing?
need a template measured and drawn.
how complex Chris?
I did graphics in grade 9 & 10 and have CAD software here at work, if it's not too hard I may be able to manage it.
R32 GTR tach panel - need to make a drawn copy of it and indicate what area needs to be clear for a 4.3" lcd to sit behind it.
doing a retro nismo display for my 32.
nah piece of piss in comparison to that. I will pull the cluster and take the relevant bit out of it. you can make the call off that.
Well, finally got the stag back after being without her for about 3 weeks. Received 2 A4 pages of work done and half a page of items replaced totaling $3795 (ouch). But from the tiny amount I've seen so far it running a million times better. Pretty well completely stock apart from pod filter and exhaust system. Now I just gotta pay that off, save some more to do the suspension, fix the VCT and a few other minor bits and pieces. Need more monies so I can get moaw power. Very happy so far though.
205.2HP @ 7.5PSI with at least another 80HP once VCT and small leaks fixed.
Edited by Grimi
Hi I'm new 2 the site and just wounderin where and when u's are meetin i wouldn't bringin out my r33 gtr!!!! Can anyone attend and do many people turn up????
if you are who I think - why haven't you popped up sooner..
Good online stores to buy shoes / shirts from. Looking to replace my now stolen Vans block letter shirt and need new shoes. Went to Chermside tonight, absolute nightmare. Now resorting to online shopping from now on.
