Dan [ERD] has posted this previously, and it's not the be all and end all of oil tests but it gives you a good guide:
http://www.animegame...Oil%20Tests.pdf
wowsers. very interesting test.
seems ill try something else next time, royal purple seems the go!
but only a few of the full synthetics seem to actually look different. the rest is all very much the same with a different pretty pattern. funny how some of the cheaper oils are much better than the exy ones of the same brand.
so acording to that if i were to buy penrite it would and could only be the fully Syn....which is funny cause i used all the expensive SIN oils in my box and diff......and they blow. it was a bit nicer for about a month then back to a sticky 1-2 change on cold winter mornings (only the first change or 2). and the noise and feel are back to exactly as they were. will be trying the Redline next time on those.
nice!! decided you needed more to fill your time??
anyone here have a windscreen squirter motor for an R33, mines dead. the rear one works fine so hope fully i can just find the motor for the front one >_<
We needed a motor for the ute so instead of just buying a motor and box we decided it was better to just grab a whole car. Should keep us fairly busy :thumbsup:
Morning Mangs
Morning Mangs,
Monday :(. But last week of work :).
Finished 24 hours of le mans last night, epic. Just nurburgring to go now...
that sounds like an interesting oil you running there smity. hows the oil pressure? im still vary wary of penrite.
I noticed low pressure earlier this week, but to be fair it is quite old and I did accidentally top it up with the oil I use for the XF before happy laps... so that probably didn't help. I changed the oil and filter that arvo (using the penrite SIN again) and it has been all good since then. No issues with pressure other than that.
http://www.animegame.com/cars/Oil%20Tests.pdf
I am guessing mine is the same as the full synthetic penrite in that, just marketed under the "SIN" branding. Seemed to do pretty good in the test.
I use SIN in the diff - no complaints. Also use SIN brake fluid and it is good too.
Redline LW shockproof for the gearbox, that stuff is magic. Although, Noel, Gervase, and ERD Dan all seem to have had some issues with it forcing its way out of the breather, this has not been a problem for me so far.
Mangs,
[snip]
That is all.
What a sh*tbox! :P
Yeah it's a heap of shit lol. But it has some gauges and a pretty steering wheel and a brand new loom apparently so should be good. :thumbsup:
Yeah same mang. Trying to achieve as little as possible this week. It's 8:30 and I havent left the office yet. Great success.
same. been sitting here doing emails.
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
