Sarp Scottay.
So, go karting? When?
I'm totally flat out at work probably until end of feb... Can everyone sms me when they cannot make it? I will compare the sms-es and just try getting any sat/sun which best suits everyone.
Cool enough to give the skyline a wash today. Its so dusty that it looks like its covered with dew after being left outside on a winters night. Guess it'll look nice and shiny for the creek crossings on Sunday!
Considering we haven't had rain for weeks, and if the showers turn out to have little substance to them, they'll be no more than a trickle.
On the other hand, a week before the floods last year they were about 10-15cm deep.
