best monday ever. enough rain means i spent the day at home watching all of American Horror Story and drinking nice wine that we picked up in stanthorpe......beats the hell outta working
Morning Mangs,
On a Sunday?
Yer, every 2nd Sunday. Whats so unusual about crickets on a Sunday?
I was stoked when the initial calendar came out with barely any clashes... but now :(
any chance we can have the topic title changed so that whoretown is no longer included in it.
I cringe every time I click on it whilst I am at work.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
