Any sport that calls itself "Football" and has even less use of the feet than rugby/league has got to be a joke
This is why we cant have nice things.
On the topic of superbowl, I am a Giants fan, I am excite, I want to see the winning touchdown in the final seconds again, also DIAF Tom Brady.
I plan on eating nachos and drinking beer. Then I'll probably have a nap. Should be a good day :)
I will likely be at work, but there is a guy here who usually sneaks out to watch it, I will probably follow him.
Yeah. I was speaking to a guy who went and did it a few years ago, all i remember him mentioning is that there was way to much mud.
I like golf...
Do you like watching it on TV though?
Quiet you.
Martin having a look at tickets for Spa in September if you're still keen
Spa
Still keen, send me your itenerary so I can work out whats worth flying over for
Pretty cheap to get in standing. Just hope like hell it doesn't rain.
F*ck standing. Grandstand is where it's at.
Its Spa....definitely going to rain lol. 3 day Gold pass on Eau Rouge is only $550 or something like that.
Nice
We still on for buranda tomorrow night?
The office I am currently working at is about 5min from there... which will leave me in a dilemma - do I stay at work till 7:30 or.drive all the way home and then all the way back?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
