Boz, hotties, end.
Mangs, just got this email from Kingston park for a team challenge race deally on Thursday night.
Kingston Park
Team of 4 tis $80 each for 90 mins of racing. Part of a bi monthly 5 round series. Anyone keen? Need another 3 people to be interested starts tomorrow lol
I'm in.
I am not. Broke as a joke these days. Damn kids.
Plus no longer a fan of go karts, as I am at a serious disadvantage weighing in at a sprightly 120kg.
Just do what I do and make up for it with pure skill and awesomeness
I am just a competetive prick. If only they had a handicap system where they weighed down all the karts to an even weight :)
I could lose some weight, but then there would be less of me to go around. plus I like cheesburger too much
I am quite offended with the ammount of jokes that are made about my condition
I am what I am (in my best popeye voice)
A 120kg stick of a man
Edited by PWND
Miso you buy! Interestingly you can get childrens and full strength version, which is pretty good if you got a toothache
Not sure how I missed this earlier
Already have that. Been rubbing it into their gums to numb them but hasnt helped much
Even tried rubbing it into my ears to numb them, but still no dice
i feel ya. the up side is that the kart wont slide...cornering becomes very easy :)
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
