SWC - can do that if its all a resistive ladder. would still like the OEM radio for it. I dare say that was a sony as well.
possibly. need to see how all of it sets up.
Cool cool. Yahoo is not deliving on the OEM HU front at the moment :(
martin,
need to talk to you about drawing something for me :)
Happy to give it a shot. For the LCD in the 32 cluster, yeah?
it is. want to fix the rather expensive fk up I paid for.. I know WHAT I want and can convey what I want but it did not turn out that way hence round two..
the drawing will go to a CNC machine via a mate of mine on the GC.
Morning Mangs
Monday :(
On the bright side... happy laps and F1 this weekend :)
Yeah saw the pic on faceparty. Not cool :(.
no service manual for the sony... looks like we wing it with a scope and a meter.
Bummer :(. Was hoping the part number would help you out.
Finally heard back from the insurance guys, they are going to go ahead and repair the car. I could be in for a very long wait however as they aren't sure as yet if the IC, radiator, trans cooler and AC are damaged and need to be replaced... Considering it took PWR 4 weeks to make my previous trans cooler and radiator if they do replace them I'll be sans car for another month. IC could be another problem as Blitz don't make that particular model any more :( Le sigh.
Oh yeah, and they haven't even looked at what caused the engine issues like it loosing fuel and becoming completely unresponsive or the surging and then almost stalling idle when I started it up the following day.
I'm not pissed that they are repairing her, I'm actually happy about that. I'm just not sure I'm going to like the wait considering it took them over a week just to make an assessment on the car in the first place.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
