In other news, oil and filter change on a VG30DET? Engine out.
do it from the bottom. get dan to toss it on a hoist.
did I see habib out at the downshift meet this afternoon?
couldn't see Noel anywhere, but looked like habib parked out by the entrance
spotted your 32 as I drove out of there in my toy car :action-smiley-069:
quite likely, he said he was gonna head there this afternoon. i was too...but then i would have missed the F1 :thumbsup:
It was indeed, we saw pwned and looked over the whole joint and couldnt find you.
I drove past that meet coming back home from bunnings, didnt realise it was on and was wondering where all the imports on granad road were coming from! Looked like a very good turnout.
I am only little and easy to miss
I didn't see your car until I was driving out so didn't know to keep my eye out.
Was a lot of cars out there. My car looked stock compared to some of the things rolling through.
They are claiming over a thousand cars. Not sure if there were that many (at least not all there at once) but there were a few hundred easily.
have to take the intake runner off to get the injectors
and the timing belt idler/tensioner mounts off that, so you have to take the timing belt off
in short:
filter change = engine out
injector change = engine in pieces
