What happened to the job at Indooroopilly? Thought you were meant to be working on the renovations there.
Also, if you end up working on road projects I'm going to hold you personally responsible for every pothole I hit from now until eternity :P
We still have the job at Indro but looks like I'll be changing jobs. Got a job offer that is pretty much twice what I'm on now 14/5 roster with 2 days for flying.
Find any TIs?
+1
f**kin unlikely you'll ever be driving on these roads anyway
Easy enough to blame you any way
sweet news on the job offer!
so is that 14 on, 1 fly, 5 off, 1 fly?
Yeah that's pretty much how it goes. Director wants to have a meeting on Monday to discuss it but I'm pretty set on leaving. Will be putting in my resignation on Monday and then probably be starting out there in the 22nd of May or something like that. Need to hang around to get completion stuff sorted on this project.
Relevant
Mmmmmmm...
no parts to work on the leopard and too raining to work on the skyline
lazy sunday it is
I've got 2500 words to write and so far all I've done is watched Top Gear and Jimmy Carr...
After fitting the exhaust my coilpack misfire (or so i assume) seems worse. (although it only happened on track...not after i left lakeside)
there are plenty of threads on coilpacks etc on the forums, but i thought id come ask you guys personally. ive done the tape and silicone thing about 40k ago, and has lasted well since then. but now its time to replace. so my question is......(drum roll)
are yellow jackets, or the red coilpacks any good? or should i just go for the splitfires for a whole lot more folding cash? i wanna stay with standard location and fitment for the sake of keeping it neat underneath with minimal hassle (yeah i'm a bit slack at times)
I'm running yellow jackets, no complaints so far!
Straight fit and they are working like a charm.
Might be worth checking your voltage at the coil packs though, as my missing was caused by voltage drop in the wiring, fixed by a relay.
In other news, morning mangs, f*ck mondays. Did manage to get some work done on the leopard (re-fitted coil packs and replaced fuel lines), and the sun came out so I could at least swap the tyres back on the wedge.
Now definitely need leopard parts for more progress :(
cheers man, i heard you saying something like that the other day about the voltage drop. i can fix pretty much anything mechanical...but am entirely useless when it comes to electrics. So i really wouldnt know where to start. could prob find the right wires, but as for testing...thats where i get lost.
yellow jackets might be the go, my old coils have done 40k with the tape job done and that lasted a while (might even have another look)
in air I am told :)
wet morning is wet. bludging net access off mcd wifi.
martin, should have a number for you today. hoping to get the 31 on a hoist today at some point as well.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
