What happened to the job at Indooroopilly? Thought you were meant to be working on the renovations there.
Also, if you end up working on road projects I'm going to hold you personally responsible for every pothole I hit from now until eternity :P
We still have the job at Indro but looks like I'll be changing jobs. Got a job offer that is pretty much twice what I'm on now 14/5 roster with 2 days for flying.
Find any TIs?
+1
f**kin unlikely you'll ever be driving on these roads anyway
Easy enough to blame you any way
sweet news on the job offer!
so is that 14 on, 1 fly, 5 off, 1 fly?
Yeah that's pretty much how it goes. Director wants to have a meeting on Monday to discuss it but I'm pretty set on leaving. Will be putting in my resignation on Monday and then probably be starting out there in the 22nd of May or something like that. Need to hang around to get completion stuff sorted on this project.
Relevant
Mmmmmmm...
no parts to work on the leopard and too raining to work on the skyline
lazy sunday it is
I've got 2500 words to write and so far all I've done is watched Top Gear and Jimmy Carr...
After fitting the exhaust my coilpack misfire (or so i assume) seems worse. (although it only happened on track...not after i left lakeside)
there are plenty of threads on coilpacks etc on the forums, but i thought id come ask you guys personally. ive done the tape and silicone thing about 40k ago, and has lasted well since then. but now its time to replace. so my question is......(drum roll)
are yellow jackets, or the red coilpacks any good? or should i just go for the splitfires for a whole lot more folding cash? i wanna stay with standard location and fitment for the sake of keeping it neat underneath with minimal hassle (yeah i'm a bit slack at times)
I'm running yellow jackets, no complaints so far!
Straight fit and they are working like a charm.
Might be worth checking your voltage at the coil packs though, as my missing was caused by voltage drop in the wiring, fixed by a relay.
In other news, morning mangs, f*ck mondays. Did manage to get some work done on the leopard (re-fitted coil packs and replaced fuel lines), and the sun came out so I could at least swap the tyres back on the wedge.
Now definitely need leopard parts for more progress :(
cheers man, i heard you saying something like that the other day about the voltage drop. i can fix pretty much anything mechanical...but am entirely useless when it comes to electrics. So i really wouldnt know where to start. could prob find the right wires, but as for testing...thats where i get lost.
yellow jackets might be the go, my old coils have done 40k with the tape job done and that lasted a while (might even have another look)
in air I am told :)
wet morning is wet. bludging net access off mcd wifi.
martin, should have a number for you today. hoping to get the 31 on a hoist today at some point as well.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
