all good. just sorted it. $100
yeah, old plates are still around. Currently one is sitting on the bike, but will probably get it back on the car, once it's running.
depending on finances, could be a while before it's on the road.....
Ok, picking up the rolling shell Thursday. Anybody with towing connections, let a brother know. Caboolture to Bellbowrie
I saw you post this on Facebook today lol
It was just near Chermside, but he towed it up there to keep at a friends. Wish I had called him earlier.....
He's a member on here.
Picking up next weekend now, as I can't get up there in time this arvo, and he'll be away till next week.
  • 4 months later...
  • 4 months later...
BUMPAROOO
I live in Auchenflower and have been very quiet on SAU in recent years.
Wondering if there are normally any weekend drives over Mt Glorious/Nebo for example?
I also ride and compared to the bike scene, the car scene seems to be very quiet?? You can always bet on a squirt up the hills on a weekend morning.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
