Don't mean to bother you again , but have not recived pic's? and because of what you said about yellow I may go Aqua , pic's please
Good work :>
  • Replies 207
Good work :>
hey champion i sent you the email ?
maybe the files are too big for HOTMAIL ?
ill try again
chears
MELV
^pilotboy^ - 390$ for two sets :)
i was just wondering would the neon be powerful enought to produce the light through a laser cut templete and show names on the road? =] I wouldnt mind ZOIXY on the ground on an angle like on the stadium ground on the road behind me, because thats where most of the people are when I'm on the road. :)
I got a set of Blue Neons off Melv and they are FU*King great, I installed them myself on my R32. They are much brighter then autobarn crap.
If you want undercar neons, buy these!!!
wow!! its so bright! thats insane!
Hey melv, do you have silver at all?
my car color is silver, the same as the R32 with the blue neons above.
what do you think would best suit it?
i want it to look clean and professional, not too crazy :(
as long as u have some idea of wiring and electrics the u should habve a problem putting em on............
luckly my brother inlaw is a sparky so i had help but it was a home job
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
