  • 3 weeks later...
  • Replies 207
MELV, got any pics of red ones yet? i still want them (dont make em up just yet) but not for a lil while, getting wheels first...btw, saw u at broadwater the other night (sat), car looks good...
what colour do u guys think would look best on a red car?
im interested in:
white
red
blue (the really bright one on the R32)
maybe some other funky colour that you guys come up with (not pink)
Guest Munky
How bright exactly are these kits? I prefer neons to project a relatively dim glow on the pavement (so it is in fact more of a glow and not a solid light beam as some of the pictures in this thread show). Is there any way of changing the strength of the glow?
Also what sort of dimensions/how many bulbs would be needed to fit out an R34?
Finally, are they legal in NSW, and are the bulbs actually made of glass?
Please try answer all the questions and not just the last one. I hate it when people do that :)
Cheers!
