  • Replies 188
OK, 53 preople ready to rock. I think we can have maybe 1 more, with the assumed 5% no shows.
The names are: Drum roll please
Oz
321_go
321 Friend Shane VL
Kinks
Flip
Akira
Endorean
B-Man
Majanal
Majanal friend Rhys
Lozza150
Slo200
Slo200 Friend Datsman
Telej
moemoe
Listen 180SX
TonyGtst
Eav001
GTR-8OY
Dave CWH-08U
BBenny Friend Ribbo
BBennt Friend XXX
Pro_32
Zane 1/2 Day Morning
Fatz
Caferacer
Tonkotsu Flavour
Crazy 180
Stuart (STUGTR)
Tony
Arthur
Mark
Ned 1/2 Day Morning
Ned friend xr8 1/2 Day Morning
Nathan
Zaero
Abo Bob
Bakadesu
Backup
(Silvia)Zman
(Silvia) Crazy 180 Grey spec
(Silvia) Crazy 180 yellow spec
(Silvia) Nisom 180
(Silvia) Quacker
(Silvia) Boxhradmr
(Silvia)16a6w6s6
(Silvia) Pro.180
Schmango
Reedy
Dark wave
Enilyks
Listen 180 1/2day arvo
Maj friends 1/2 day arvo
GTR-8OY friend Orhan Com
GTR-8OY friend Murat soarer
Se you all brign and early on Sat morning.
Thanks Oz
Just so it is on this page...
I'm out guys.. Don't really want to take a trek out to EC with a noisy timing belt. Maybe it'll be fine (I took it for an italian tuneup this afternoon in frustration) but then again maybe it won't. Need to get it checked out to make sure I won't suddenly become very poor :D
Might come spectate in the pulsar, see what happens..
Hey guys,
michael here with the matte black 180sx.
Great to meet you guys yet another friendly bunch od people I've met through car stuff. I'm a mod on Silviansw.com and a member of NissanSilvia.com where I saw this event posted.
I understand that most of your stuff will be focussed on the Skylines, but did anyone get any video of me at the end of the day on the figure, when I was getting better?
Great day, thanks for organising.
Hey Michael, Good to see you there man !
Hey - Tell Snezy he's a slack **** and that he should have come down to see B-Man el dorifto ! he he he he he - It's all good !
BIG thanks to Oz for organising a TOP day !
I was a spectator all the way from orange, 3 hrs away i woke at 5:30 and it was worth it, My god the cars I was in heaven.
My vote goes to the '321 GO' and that maroon silvia, absolue legends. The car I loved the most would have to be 'GTR 80Y' or 'CWH O8U' they were sweet. I only wished I paid 100 and drifted my crappy r30 hey its not fast but still drifts.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
