is anyone else getting a tad over seeing commos on the road with chevy rear/front badges?
fark theres more holdens with chevy badges here than there are actual chevys in america!!
are they factory optioned or something?
i know its coz of the v8 engines in holdens but theyre GM engines, theyre not built by chevrolet they just happen to be used in them aswell :D
arent the americans meant to be the "less educated" ones? i bet if you went over there you wouldnt see a single corvette with holden badges on...
ive decided to get a 2jz transplant and stick toyota badges on my car. screw this shit :D
/end rant
Edited by R-SPEC
https://www.sau.com.au/forums/topic/261529-holdens-with-chevy-badges/
  • Replies 43
I was over it 20+ yrs ago, when every 1 tonner had one, a mate back then even had one on his HQ sedan...
Admittedly it had a 327 in it but still I hated it like I would a ginger headed step son.
Wtf is with commondorks with Pontiac bonnets and Chev badges though?
Some sort of identity crisis.. They're all ugly, that's all that matters.
Lexus Soarer ... Toyota Soarer ? any different ?
i've seen Toyota Soarer..... then a few months later same car has Lexus tags on them
I see a lot of that too but to the Toyotas boys credit, other than the badges they are actually the same car most of the time
oh god ive seen this soooooo much lately - was speaking with some mates about it and they all were sick of seeing every 2nd commo with a chev badge - put a f**king vauxhall badge on it you sheep!
ive seen one with a Lexus badge on the back and a Toyota badge on the front.
I purchased my Calais with the chevy badges already on it. Can't say it would be something I would have done myself but the Idiot had removed all the Calais badges which I put back on. I've removed the chevy badge from the bonnet and left the boot garnish & wheel centres as chevy. CBF changing them.
i dont see what all the fuss is about.. i mean is the world really coming to an end if people put a better looking badge on thier car?? (which kinda makes sense for the LS1s ect.)
i see nothing wrong with having a bow tie at the front or back of an SS, clubbie or the like so rimon find something else to b!tch about mate... lol
p.s. i havnt done it
It's a bit Michael Jackson when you think about it, no matter what he does he'll never be what he obviously wants to be.
Mmmm chevy badged comms will now be know as thriller edition comms.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
