I'm new to the street performance scene as i've only owned 2 nissan pulsars (89,91 models). I recently baught a 32 GTR with a 33 GTR Vspec II engine. I love it to bits.
When i purchased my baby the dude told me to service it, as it has been a while. I said I will service it as soon as it was under my name. (Turned out to be a stupid idea).
After a week of him fudging me around about the roadworthy, I started hearing a clicking sound as i accelerated. Called a freind immediately and he told me it might be a piston. So i drove it to
work, planning to get it checked out the next morning. I took it to Rajab Racing and the gentleman told me that my engine was gone, turned out that my baby had no oil in
the engine. He continued to tell me that because it was dry, a piston had crushed a bolt (me not quite understanding), and that the piston was hitting against the housing.
I'm crushed, i've been told it will cost me a fair bit for a full reconditioning. I have also been told that it may not be as bad as he is making it out to be.
What info i'm after is how bad these cases can get, I have driven the car about 1 hour after the sound (on the road), it is now sitting in my garage. Is one piston repairable or the nut whatever
the case may be. Also what the roadworthy covers, because i beleive he has gotten a dodgy one. (The battery isnt fastened down, the ricaro bucket seat needs welding on the drivers side, and a
few other little bits and peices)
I KNOW I'M AN IDIOT FOR NOT GETTING IT SERVICED IMMEDIATELY, either way, any information would be greatly appreciated.
Can my baby be saved?
no oil? the dude needs to be shot for not having any oil in it in the first place.
Kyriakos needs a swift boot up the rear for ignoring:
no oil pressure showing on the gauge.
"Oh Shit" oil pressure warning light shining brightly.
If he bought the car privately, fair trading laws don't apply. And it would be difficult to prove that the seller was at fault, anyway.
I feel for you mate, your situation really does suck!
Fair trading laws would apply, but court procedures take a long time and it would be difficult to prove the seller was in the wrong, and even if you won there is no guarantee that you would get the money straight away.
more than likely you would receive small installments over a long period of time.
i am no expert but i am studying law so i've got some sort of idea.
i've spun a bearing in my 32 GTR and am getting a rebuild done in a months time. and the build will take around 5 weeks so i am without a car for over 2 months. it sucks but you just gotta make the best of a bad situation.
Brezza
Ok a few things don't make sense for me, please clarify.
After you purchased the car, how much driving did you do?
For a car to have no engine oil, it would nearly immediately start failing after you started it. You would hear some awful noises, other than just "clicking". I am amazed you could even drive it down the road.
For the previous owner to not have any oil in it is highly unlikely. So was it just a bit low on oil?
If it in fact had no oil in it, how did you not have an engine oil light come on, or the fact the oil pressure gauge would have sat on zero?
In other word's what im trying to say is there in no way in hell that the engine had no oil in it, it would fail almost instantly, let alone drive around with just a clicking noise. Also, the entire engine would be f**ked: Bearings, cams, turbos, rings etc. Not just "a piston".
Have you taken the sump plug off to see what is actually in it?
Edited by PM-R33
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
