i know there is a few topics on it already but they are old and i was wondering if anyone has been running straight avgas without killing the engine,
i use to run my old civic on it, but it burn out all the exhaust valves, but doesnt the rb26 have sodium filled exhaust vales or something??
not too worried bout the o2 sensors as they're prob already dead
not doing it for performance gains, just coz i get get hold of a bit here and there
https://www.sau.com.au/forums/topic/262343-avgas/
Umm, don't run it straight, best to mix with petrol 50:50, then ignition timing can be advanced (tuned to suit of course).
Don't run a cat converter, it kills them too.
It's not street legal....
That's all we have found.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4493798
a few of the boys at work mix it 50/50 and throw in in their motorbikes, saying that people usually take it from the slops tank, so make sure you drain for water content before adding to your tank.
it does require a tune to run properly, i stay clear of it personally unless you can guarantee a sufficient supply to mix half half all the time and tune to suit.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4494585
Yes it will destroy a cat. It's leaded and it clogs up the cat. Makes it overheat to the point of glowing red and destroys it. I've seen it happen.
Dearlove, you might want to look into water/meth injection as a cheap option for the net effect of higher octane gas. Is it something you want to run all the time or just for track nights? If just track nights, you could also make some of your own high octane brew with something like tolulene (sp?) of xylene. Has the effect of taking US R/M+2 93 octane gas up to around 98 octane. What do you guys have down there? Av gas is only like 106 or there abouts IIRC.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4494751
lol 106? id b shitting the gear if i could get my hands on some of that...if its tuned on 98 then 106 is going to make fkn absolutely no diff other than protect ur engine slightly from det...waste of time... rather stick 100 shot up it then tune it on that crap...at least it would have some valuable effect
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4494815
Because it contains lead, it is illegal to use it in a car complied to run unleaded. It will kill the O2 sensors, and the cat. (and de-catting is also illegal).
Before you get caught with it in the fuel tank, make sure you have a very good relationship with your local bank manager.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4495296
It doesn't kill 02 sensors - we have an XR6T that has covered thousands of kilometers on avgas without destroying anything - mind you it doesn't have a cat. And as for red exhuast thats crap. It leaves a white residue in the exhuast system thats why it makes reading plugs more difficult too - as they appear alot whiter ie- hotter than what they actually are.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4496177
Gee maybe they painted it red then. my mistake
i just mentioned it because a friend of mine run it in his Supra for a while and the inside of the tip on his cannon muffler went red.
I love SAU. Its the one place to go when you want to make someone get all uptight.
Keep it up.
Edited by gotRICE?
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4496379
HAHA, no im not stealing it.
i work in the aviation industry, thats all
and i know a bit bout the fuel,
it burns slower than 98 therefore increasing its detenation charateristics, and in turn it burns hotter, and killed my poor litle civic engine's valves
it doesnt make the exhaust go red but when running really rich i have seen it going 'sort of white' but mostly black
its got alot of lead in it, say the old leaded fuel for cars was like 0.05g of lead or something, avgas is about 6g (my numbers my be a little wrong) thats why they are trying to get rid of it just like in cars
it has a lower reid pressure, cant be bothered explaining, plus it doesnt matter if your running it in a car.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4496670
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
