If you want to get the same performance as this, without the hassle of having your car off the road and getting your hands dirty, give me $160 in $10 notes.
The weight reduction in not carrying over a dozen notes will be even more beneficial than sticking an intake restriction on your car.
  • Like 1
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-4601749
  • 5 years later...
been seen these ands on the tv for these hyclone things they fit into the air intake pipe and apparently make better air feul mixture. on the ad they say up to 15% more power and better fuel ecconomy. i wanted to know has anyone got one? they can be used on turbo setups aswell but un N/A guys are always in search of cheap power!!http://www.fuelsaver.com.au/what do u think bull shit what
I don't know, it's a big debate...
It totally makes sense that you'd think it would just restrict your air travel into the manifold.
But on my Land Rover Discovery-ES 1994 V8 3.9L model I managed about 23% increase in mileage on the highway with x2 Hiclones fitted after comparing previous interstate drives (and I drive non-stop)!
Air density could of played a role, but it would still make at least 15% more mileage on the highway with a steady stabilized foot throttle position!
But for city stop & start driving, forget it!!!
Only good for interstate driving in my opinion!!!
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7524056
Did you do another long drive without Hiclones fitted but with new air filters?
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7524229
I started with a K&N Air Filter.
I was doing thousands of kms prior to swapping for x2 Hiclones & I always managed more kms on the highway!!! :)
So I only have them fitted on x2 of my vehicles...
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7525301
Whatever the Tune may be.
Discovery Series 1 is the only vehicle besides Commercial, that could handle 4.500kg towing these days!!!
As you can get Iron Man B Rated Coil Spring for the rear & mine weighed 2.5t wet weight (no sway with a tri-axle flatbed trailer loaded)!
As Dodge RAM 3500HD, Chevrolet Silverado 3500 & Ford F-350 all count as Commercial Vehicles on Rego...
With Dual Sun Roofs, V8 & full leather you seriously can't go wrong! :)
https://www.sau.com.au/forums/topic/262351-hyclone/page/2/#findComment-7525771
  • 3 months later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
