DETAILED SEVERE THUNDERSTORM WARNING
for LARGE HAILSTONES and FLASH FLOODING
For people in parts of the
Sydney Metropolitan and
Blue Mountains/Hawkesbury areas.
Issued at 7:03 pm Wednesday, 25 March 2009.
The Bureau of Meteorology warns that, at 7:00 pm, severe thunderstorms were detected on weather radar near Richmond, Wilberforce, Bringelly and Mulgoa.
These thunderstorms are moving towards the northeast to southeast.
They are forecast to affect Badgerys Creek, Leppington and Oran Park by 7:30 pm and Campbelltown, Hoxton Park, Macquarie Fields, Maroota, Minto and Wisemans Ferry by 8:00 pm.
Large hailstones, very heavy rainfall and flash flooding are likely.
The State Emergency Service advises that people should:
* Move your car under cover.
* Keep clear of creeks and storm drains.
* Don't walk, ride your bike or drive through flood water.
* Unplug computers and appliances.
* Avoid using the phone during the storm.
* Stay indoors away from windows, and keep children and pets indoors as well.
* For emergency help in floods and storms, ring the SES (NSW and ACT) on 132 500.
The next warning is due to be issued by 8:05 pm.
https://www.sau.com.au/forums/topic/262660-hail-warning/
FAIL, LOL
CANCELLATION DETAILED SEVERE THUNDERSTORM WARNING
Issued at 7:46 pm Wednesday, 25 March 2009.
While thunderstorms are continuing in parts of the Sydney region, the immediate threat of severe thunderstorms has passed. The situation will continue to be monitored and further warnings will be issued if necessary.
https://www.sau.com.au/forums/topic/262660-hail-warning/#findComment-4498458
  • 5 months later...
Made it home with 2mins to spare before hail came down on Sunday for a couple of minutes. Im paranoid these days as our BA falcon got dented up real bad in that big storm back in Dec '07. That was the one that wiped out all those house roofs across Blacktown, Seven Hills etc. Took 9 months to get into a panel shop!
https://www.sau.com.au/forums/topic/262660-hail-warning/#findComment-4840552
Can someone update me if there is hail?
I need to drive the bluebird there...and the mrs needs to drive her 323 there too :D :D :D
Want to drive the my boat there too? I figure I'll turn my car into a pure track pig if it gets written off by hail :)
https://www.sau.com.au/forums/topic/262660-hail-warning/#findComment-4841029
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
