Did a search and couldnt find much to answer my question.
So Im looking at an R34 and the owner has fitted a gtr-s (quoted as running 11psi) but has retained the standard ecu? car has been driving like this for 15,000km (18 months).
Does this sound right?
Surely the stock ecu is struggling to work out what is going on and the car would drive pretty ordinarily... i'm kinda assuming he's had something in there ie pfc, which he wants to keep post sale. Mods include - ebc, full exhaust, 040 pump, front mount and zorst.
Cheers
A point about your question...
The ECU has no idea what size turbo you are running...The good thing about engine management platforms that use MAFs is you can do a lot of mods and the stock ECU will handle it. Safely!!.. Platforms that use MAPs are a completely different ball game...
All the stock ECU is worried about is airflow. It matches fuel to airflow. If your airflow exceeds a threshold (which increases with rpm) it progressively cuts spark. This 'is Not' R&R. R&R is triggered by pre-ignition. This is one of the most misunderstood things on these forums.
I run a stock RB25DET ECU on an RB30DET with a GT3076R and have done so for 2 1/2 years now. It makes around 280rwkw and afrs are safe. EGTs are good as well. I get around airflow cut by changing exhaust cam timing and introducing a little bit of lag. The ECU doesn't like too much airflow at too low an rpm and if you avoid this, the setup works well.
This is not crap and dyno runs were done by a well respected tuner on these forums...
So IMO I think your engine will be fine. Airflow cut is the saviour and will occur well before any overly lean conditions occur...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
