PWR twin pass alloy radiator (one of the big ones), stock water pump & thermostat.
After about 8 hotlaps of QR on a 30 degree day, water temps peaked at 83.. normally sits on 79-80 while cruising. I have moved the oil cooler and removed the aircon so the radiator gets better flow, but aside from that, nothing fancy cooling wise.
if you have the time/money, its not going to hurt.. just doesnt seem necissary.
As i say i have not had a allot of issues, I done the Winton 6 Hour and share drove my car in a team, and it done 2 hours, and by the end of the day on the first year (36 or 38* day) it was starting to feel it, more than anything the power drop off from the heat soak. That was with STD boost, 600x300 fmic, 52mm koyo radiator, and Nismo thermostat. I don't think you can stop the heat dropping off your power completly, but i am going to try it and if it helps. Well bonus, when the sprints are on and it's over 35 degrees, now that i am running between 12-15psi i cringe and usually give the event a miss. If it helps on those days, without having to back the boost off much, or alter my maps much; well i really would be happy. If it dosn't well, i have wasted more money on on other 'performance parts' that haven't given me a gain before.
He is not up here this weekend, but i can grab an SR20 pump that has the same impellor on it, and take pics.
Cheers Guys.
That's the advantage of this setup, most people don't realize that there car looses power after long periods of full throttle, try holding any car flat on the dyno for two minutes. Setting up the cooling system right prevents steam pockets or hot spots from forming in the head, which can stop valves from seating properly and uneven cylinder preasures leading to power loss. Obviously this probably isn't that much of a problem on a street car car, but on a track car the advantages are there.
Nathan
A word of advice; I've known John since 1995 and it took me 2 years to get a coolant de-aeration tank and thermostat relocation kit off him. Get a spare and ask him to work on it so you don't have your car off the road waiting for him.
It's all good in principle but the Jensen engine I spoke about in the link in your opening post was a basket case and prone to overheating no matter the size of the radiator or thermostat temp as it was a boiler in that configuration. I also saw the test rigs he made that showed the GM and Ford oem stuff reversing or stalling coolant flow. The RB is a different story as it isn't prone to overheating and in the case of at least the RB26 has an oem air bleed.
For $250 or so I think it's worth trying IF he can convince you that the oem unit is rubbish. It might not be perfect by his standards but if it's adequate then why bother. If you do get one please do back to back dyno runs to see if it affects anything at all ie power, torque, inlet temps, boost. ign etc. otherwise it wil be hard to know if it's made any difference.
In the case of the Jensen his ideas did make a huge difference but like I said it was a basket case.
I will actually grab the cut up head over the next few days, and take some pics of the flaws in the top of the water jacket castings, there tend to be high pockets above the exhaust ports, that create hot spots, in an already hot point, he then drills and taps a bleed into that pocket so that there is coolant flowing through that point, and any air is returned. I honestly did not think that they were as obvious/large as they are. (there is a noticeable pocket present).
Cheers Guys
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
