  • Replies 203
Management consultant in what field Tony? I was really interested in Change Management but getting into the HR side of things was difficult as its about 90% females
I'm a Management Accountant but actually doing my Masters in IT Development in the evenings.
I work in a restaurant.
Good tymes.
hows the rosemary?
*baddum tish*
@Tony,
thanks heaps mate but i decided corporate HR isnt for me. Moving into the IT development side of thing is keeping me on my toes and im really enjoying it
Me and my mrs want to move to Brisbane next year, and Infiniti in Brisbane are taking applicants as of end of this year.. Might end up working for them when i head down there. That would be awesome!
Edited by Seano350GT
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
