Selling all my stuff decided to go a 26 in the car instead.
So Here we go.
Turbosmart Pro Gate 45mm $600
GT3540 Never used, 0.82 Rear comes with oil and coolant lines. $1700
6boost Manifold to suit 25 external wastegate, has V-band flange welded on. $800
550cc x 6 injectors one injector sticks open thou. $400
Adaptronic ECU with 3bar Map sensor $700
RB25det Neo motor with greddy copy intake and 80mm throttle body, with 750cc R33 injectors and rail.
motor has done 76k, Has only ever ran stock boost.
No turbo or manifold. $2000
All parts are open to offers
Parts are located in Perth, Thornlie
https://www.sau.com.au/forums/topic/262925-rb25det-engine-and-am-parts/
manifold, turbo, gate, 750cc injectors and rail, and intake plenum is sold pending payment.
RB25det Neo motor no turbo, manifold or injectors or intake plenum
$1200ono
sorry it went today.
Only got
$1100ono
motor has done 76k, Has only ever ran stock boost. i do have stock plenum but missing couple things, and throttle body.
$1100ono
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
