Hi all
I am on of the only people in the NT that has a greddy emu. No one has experience with them here so does anyone have base Airflow maps for the Greddy pressure sensor, or do i need to collect the data on a dyno like this http://www.skylinesaustralia.com/forums/ma...p;hl=greddy+emu thread suggests.
I havent been able to drive my car for a while, so if anyone can help it would be great.
My car is:
1992 r32 GTS-t Auto - no mods
Thanks in Advance
Greg
(Also i am having issues with the car shifting from 850 - 1250 rpm when idling and the car running too rich, Do i just need a tune?)
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/
Hi all
My car is:
Thanks in Advance
Greg
If your maps are all at 0 adjustments then you shouldnt have a problem. download and run the file below, its got 0 adjustments and is set up for your rb20. as long as you've wired in the EMU right it should work 100%. I've also set up data logging so you can look at all of the right parameters when diagnosing problems.
r32_r34_map_no_adj.zip
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/#findComment-4503266
Cheers, i was beginning to think no one used the emu
I'll see how it goes, i had trouble wiring it up initially and had to take it to one of the tuners here, apparently the injector connections were back to front someone had messed with the factory computer loom. He said that all of the setting were set to zero and hence i should be able to drive it around,
However....
Right now when you depress the accelerator there is a delay before the engine kicks in and at idle it pulses from 850 to 1250 rpm.
Furthermore once when i was driving it after it was installed, if i depressed the accelerator the car spluttered and sounded like it was going to stall, i then pulled over and restarted and it was fine?
Once again Thanks for your response, i appreciate it!
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/#findComment-4503658
i used an emu for around a year, its a good piece of kit but it can definitely be a headache if not wired in properly. check if the map i put up fixes your problem, if not its possible its a wiring issue or even your jumper settings on the board of the EMU are wrong. also if it doesnt help i'd need a bit more info on whats happening to be able to help you out.
do you know how to read a data log properly to find faults?
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/#findComment-4504402
Hi
I personally have not interfaced the the emu, i am a little worried about stuffing up my engine. So on Tuesday i am taking it to a tuner to have a look at it however since he has not had experience with the greddy emanage ultimate, i have to find all this stuff out myself.
So, so far i need to:
Open your file and update the emu,
Check the wiring and jumper settings,
Use the Data logger to find issues,
Most tuners in the territory are used to powerfc's, haltech's or Wolf3D's and since i dont know how to tune and have an automatic, i have to decypher the emu for the tuner i use.
Thanks,
Greg
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/#findComment-4504595
yeah, all of my tuning was vs. psi.
plug in the sensor, set up the OPTION 1 or OPTION 2 (the 2 expansion ports on the front) to whichever the sensor is plugged into, plumb it into your plenum then off you go. its all in the manual.
i actually sold off all of my emanage stuff a few weeks ago including the pressure sensor and plug to input 5v from an A/F gauge.
you need to get yourself a laptop with the manage software and have a play with it yourself, especially when you're the one that is doing the research for your tuner. by the time i was getting someone to tune my car the first time i was explaining the features and helping with the tune. also helps if you have a minor problem and all it takes is a few clicks of the mouse to sort out.
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/#findComment-4505407
Hi,
What unit do i need to use to utilise the pressure sensor?
Data Sampling Map
Do i use, Throttle Position, Airflow Hotwire, Greddy Pressure sensor, Relative Pressure or Charge efficiency.
Then i need to sample the data, Copy the data then paste that to airflow output map?
Is That correct?
Cheers
Greg
Edited by R32_R34
https://www.sau.com.au/forums/topic/262957-r32-greddy-emu/#findComment-4505779
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
