The fact that I got 411rwhp isn't of much interest. The fact that I did it on stock internals, stock cams and stock injectors is.
I had been led to believe by a number of people that without cams that I wouldn't be able to flow enough air to make that sort of power, and that I would have run out of injectors long ago. So I thought I would share this with you incase you decided you had to buy them to make decent power.
I'm running a GT30 (500hp) at 17psi. We currently only have 9deg of timing so that the stock pistons don't blow, so even with the current setup and forgies we have a heap more power available.
Hope this of interest to those of us who own whales:D
https://www.sau.com.au/forums/topic/26304-411rwhp-from-stock-internals/
  • Replies 335
I'm a bit confused from the above quote where you say "so even with the current setup and forgies we have a heap more power"
Does this mean you've got forgies or are planning to add them?
Buster, Meaning that keeping the boost at 17psi and just by increasing the timing we can get another 20+ hp easily. I don't have forgies yet, but as soon as I can afford them they'll be going in:D
2rismo, I'm sure the injectors are standard 370cc, I'm using a Malpassi fuel reg, with about 40psi of fuel pressure.
Injector duty is on about 80%, so I'm hoping to keep the stock injectors a bit longer.
Hi GTS-t VSPEC, when you say "I'm using a Malpassi fuel reg, with about 40psi of fuel pressure". Is that 40 psi above boost? ie 40 + 17 = 57 psi. Or is it 40 psi total? ie 17 + 23 = 40 psi.
Hmmm 40 psi is only a little above standard, hmmmm.
This is prety simple maths here, 370 cc's per injector, 6 X injectors, 1 firing per 2 crank revolutions, 12 to 1 A/F ratio, 2.5 litres engine capacity at 1.15 bar (17 psi) at 90% engine efficiency. You end up at 370 bhp (+ or - 5%) at 80% duration. The 20% is for acceleration enrichment, ambient conditions, cold run etc
So 411 + (say for losses) 70 = 481 bhp. That's 130% duration.
In order to get the sort of flow we would have to increase the fuel pressure to 60 psi above boost. In your case that would be 77 psi which is 4 psi above the Bosch Motorsport fuel pump maximum. There are other pumps rated higher of course, but hen you start to run into other complications, hoses, clamps, voltage drop etc.
I'm perplexed??????????????
Hi Buster, you asked "do you use a fuel reg on all your cars or is it only needed if the injectors are maxing out?"
Adjustable fuel pressure regulators are a bit of a "band aid" really. They are OK to fix a slight problem when budget is a concern (as it generally is). Bottom line, I prefer to get the right size injectors in the first place.
Hope that helps
Hi R32-GTS, it has been my experience that the laws of physics always apply. Whenever I search enough, I can find an answer, and restore my faith in the laws. There is obviously a reason for it, we just need to find it.
This is pretty simple;
either the injectors flow more than 370 cc's
or
the fuel pressure is more than 40 psi above boost
or
the calorific value of the fuel is higher
or
well, let's leave that one............
Hi guys, there are a couple of other clues here....
Simplistically, boost is resistance to air flow. You run higher boost because the engine won't allow the air to flow into and out of the combustion chamber. The GT30 at 1.15 bar is a little under its most efficient ie; a bit below the sweetspot on its compressor map. About 1.3 to 1.5 bar is pretty much right in the middle to achieve its 500 bhp rating. Now 411 rwhp (480'ish bhp) is pretty close to 500.
My experience has been that a standard flowing RB25DET (standard cams, ports, inlet manifold etc) with a "perfect" intercooler and exhaust manifold, needs 1.4 to 1.5 bar to overcome these standard restrictions to air flow to make 450 bhp. Reducing the restriction (longer duration, higher lift cams and port work being the main ones) you can get 450 bhp at lower boost levels (1.1 to 1.3 bar).
To make close to 500 bhp, I would have to run 1.7 to 1.9 bar, which is past the max efficiency point of the GT30, but achievable.
So I'm perplexed over this as well...............
Sydneykid, Glad I've got you stumped on this one, I was shocked aswell. I know I only put BP 98 in the tank, mixed in the correct proportions with Octane booster. The injectors have been in there since I bought the car, and the car was 100% stock when I bought it, so I'm confident that there are stock. I would agree that sizing the injetors to meet the application, but seeing as we're not even at 90% duty cycle then the stock injectors are working great.
I'm using the stock fuel pump as a lift to a 3litre surge tank, then a 910 Bosch pump into the Malpassi.
I have the Greddy plenum, 100mm throttle body, custom exhaust manifold, R34GTR intercooler, if that helps with any of your calculations;)
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
