Hi MiniMe, there are a number of ways to look at "engine efficiency". One is that a petrol engine is around 65% efficient in using the energy stored in the fuel it uses. This of course allows for the power consumed in driving the ancillaries (water pump, oil pump, A/C, power steer, alternator etc) and the losses through the drive train. The other 35% goes mostly in heat into the water and oil etc.
The lower numbers (35 to 50%) only compare the calorific value of the fuel versus the power at the wheels. That's why the numbers are lower.
The basis of all these calculations are based on Newton's theory energy can be neither gained not lost, it is merely converted into other forms of energy". Einstein of course disproved this with E=MC2, but for the course of this post I will assume no atomic reactions going on in my Skyline.
What we were talking about in the previous post was the efficient use of airflow ie; how much air is available versus how much the engine ingests. Numbers like 85% for a pushrod Windsor V8, 92% for a modern twin cam 4 valve, 97% for a Formula 1 engine etc.
Simplistically, that means a 2.5 litre engine at 1 bar only uses 4.6 litres (not 5 litres) of air every 2 revolutions of the crankshaft based on the 92% efficiency rule of thumb. Since we know that RB's produce best power around 12.5 to 1 air/fuel ratios, calculating the fuel required is easy.
Hope that answered your question
  • Replies 335
Simplistically, that means a 2.5 litre engine at 1 bar only uses 4.6 litres of air every 2 revolutions of the crankshaft
1 bar?
Is there a forumula to work out the amount of air a 2ltr for example is using at 7000rpm with 92% Effiency on say 10psi.
which has in turn, been disproved, Capt. Accuracy!
ROFL... i'm just causing trouble now.... This is an interesting discussion especially for us cheapskates!!
Keep it going.
Oh and GTST_VSPEC, run the thing will ya? please? give the cheapskates some hope!!
Adrian
Joel, atmospheric pressure is 1 bar, boost of 10lbs is 0.68bar, added together is your multiple factor for the capacity (or absolute pressure - which is quite often the way turbo compressor maps are represented), so 2L engine times 1.68 is 3.36L of air (per 2 revolutions). With a 92% efficiency, multiply by 0.92 = 3.01L (3.091) of air for every 2 revolutions of the crankshaft.
divide 3500 (for 7000rpm) by 60 seconds = 58.3 (induction strokes per second) times 3.01 litres of air = 175.48 litres of air per second at 7000rpm.
A/F ratio of 12.5/1, so 12.5litres of air for every cc of fuel, the engine would require 14cc of fuel (175.48/12.5) per second, or 50 litres of fuel in one hour (0.014L x 3600seconds).
Also an RB25 at 7000rpm and 1 bar boost would consume 268.3 litres of air per second, so 21.5cc per second or 77.4litres per hour.
I hope those figures arent too far out - perhaps Sydneykid would like to check them for me:D
the only problem is that basic calculations like this dont take into account the density of the air due to temperature and the size/efficiency of the turbo.
there must be a method of calculating the amount of fuel required per hp and engine produces, which would be more accurate.
DISCLAIMER: I really am not sure if these figures are 100% kosher (ie method of calculation), so flame away all you mech eng types etc :D
An internal combustion engine dispenses with most of the energy in the fuel through the exhaust (30-40%) or the cooling system (30-40%). The rest (30% at best) goes into the combustion process to drive the crank. Mind you the combustion process is irreversible in nature (the products cant be recombined to form the constituents) and also governed by the laws of thermodynamics. Add in the fact that you also have the drive train losses to contend with and the petrol IC engine starts to look pretty shit indeed.
Guest INASNT
Originally posted by GTS-t VSPEC
Adrian, Trust me I'd love to run it down the strip, but on stock internals I'm not sure if it would cope. My suggestion is not to be in too much of a hurry to change injectors until it's really necessary:D
Just run it atleast once with some nittos, the engine wont be that fragile that it will break after one run
As clear as you suggestion is, i think you fail to recognise the risks associated with it. As it was mentioned earlier a fuel reg is a band aid solution for a need of more fuel, in most cases marginally more fuel. Running the pressures that you are running on standart fuel lines would not be advisable to anyone.
That's the thing; the engine does not need to be fragile to fail at those conditions. Unless you are prepeared for the worst, the outcome will leave mental scars for a while. :)
On a different note, i am detecting a bit of a dig and sarcasm towards SydneyKid. Is there a reason behind this ? Am i missing anything ?
We love Sydneykid, he's a fgreat guy and knows heaps of stuff, doesn't mean we can't pull the piss out of him occasionally:D
Emre, Rob77 is running 344rwhp with no fuel reg and standard injectors (70% duty cycle), so my suggestion is why would you change them if it's not necessary.
I'm a touch lost here (whats new though haha) so what your saying is you've now got all this power but you are to scared to run the car down the 1/4 because of the stock internals
If thats right whats the use in having the power then? hahaha you can't use it?
Originally posted by Steve
Because he can:)
:bahaha: Thats a good one, Its a damn shame we wont see any times to back up that power then, In my book it sort of defeats the purpose of having power if you can't use it or show it down the 1/4, but I guess its ok if you just want to be a DYNO QUEEN :)
Hi Steve you should have finished the calcs.............
21.5 cc per second at 14.7 psi = 24.9 cc's at 17 psi
+ 20 % enrichment (acceleration, cold run, start etc) = 29.9 cc's
6 cylinders = 6 injectors
60 seconds in a minute
299 cc per minute for each injector
Looks OK for a 370 cc injector?
Except that is at sea level, at 0 degrees C and 0% humidity. Not gunna happen on a roller dyno in Australia. That is unless someone has their dyno in an environmentally controlled room (ala F1).
So let’s deduct some;
Humidity, say 25% (it's not raining)
16 degrees C (not too hot, not too cold) that's 10% (5% for every 8 degrees)
Let’s say the dyno is at sea level, so no adjustment required.
299 + 25% + 10% = 411 cc's
Oooops we ran out of injector capacity.
None of these calcs are perfect, but I have used them often for working out approximately the right size injector, I then add 30% or so to be sure. So 411 + 30% = 534 cc's. For this engine at that power, a set of 550 cc injectors would be my starting point.
You can do this a number of ways, a good rule of thumb used by many in the automotive business is 1.7 bhp per cc of injector capacity. Thus 1.7 * 6 * 370 = 377 bhp.
So, I'm still perplexed..........
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
