Items
5. R32 GTR carbon vented bonnet
Condition
5. Decent condition, corners have been chipped, has been painted kandy red over the carbon so it looks like red carbon, paint and be removed and cleared over again so its back to normal
Price
5. $500 as is ($600 if it has to be stripped and cleared)
Location
Sydney
Extra Info
Postage can be arranged anywhere in Australia
Hi is the bonnet full carbon or carbon skin?
Does it have provision to fit the stock bonnet latch?
Are the window washers hooked up?
Thanks
Edited by FurryBarry
its carbon over fiberglass (you will never get a full carbon bonnet for $500)
yes stock latch works with it
yes window washers fit too
Hi champ,
Im very interested in whatever you have left im in Sydney Greenacre, and just recently hit my car so please call me on 0414509399
BUMP
offers please people gotta get rid of this stuff
Hi champ,
I think you called me when i was in hospital from my bike aka, Can you please call me again im in sydney and am want some parts.
My Number is 0414509399
Thanks
