ok guys i have a few models organised and 2-3 photographers... so i am going to start making a time schedule!! please tell me when you would like to go. once i confirm the amount of photographers and models more time slots will become available.
10:00 - Setup
10:15 - Brendan
10:30 - Donovan
10:45 -
11:00 -
11:15 -
11:30 -
11:45 - Lunch
12:30 -
12:45 -
01:00 -
01:15 -
01:30 -
Can i take the slot after Brendan and Don at 1045 ? Thanks
  • Replies 75
Had a couple of queries about price.
You only pay for the pictures u want in good quality, they will be given to you on a CD ready for you to print them at a printing place. each picture you want will cost $10 as they will be edited.
i dont have a car but damm i am sexy can i just get a photo shoot of me hope u got a wide angle camera :blink: (thought i would put that joke in before anyone else got the chance) im looking at u benson
LOL....... coming down in the evo?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
