  • Replies 75
SHOOT CONTACT PAGES ARE UP!!!! (without any editing, the pics will b edited after they are chosen)
http://www.flickr.com/photos/mkphotographyperth
GO THERE AND CHOSE WHAT CAR IS YOURS THEN CLICK ON THE IMAGE THEN GO TO ALL SIZES THEN CHOSE THE ORIGINAL SIZE AND HAVE A LOOK THROUGH THE PICTURES.
IF YOU FIND IT HARD TO KNOW WHICH PICTURE LOOKS BEST BUT YOU WANT ONE THAT LOOKS LIKE A FEW, SELECT A RANGE AND I WILL LOOK AT THE ORIGINAL SIZES AND PICK THE BEST LOOKING ONE!!!
PM ME THE FILE NAME (FOUND UNDER EACH THUMBNAIL)
HOPE YOU HAD FUN!!!
ADD ME ON MSN IF YOU DO NOT UNDERSTAND OR YOU WANT TO TALK ABOUT A CERTAIN PIC ETC.
[email protected]
(contact sheets will be up till next sunday first to contact me, first to get pictures edited)
was good, the chicks bailed before i could get pics with just them and my car :blink: haha next time, cheers Rob
sorry about that man, got a bit confusing near the end because the models had to bail. but they have confirmed that they are willing to do another shoot with us coz they had so much fun will be taking bookings again soon :D
better pick a better time of the day to do it next time. Exposure is all wrong due to the harsh light which makes it hard for the tog.
The cars in the bg and reflections aren't good either...gotta setup a bit better and frame the shot. Use some remote fill flashes, the models and car weren't exposed right.
just giving some advice on photo taking not editing. you can probably edit like a guru in ps or lr but if you take the photo right at the start it' less time fiddling in software.
random cars or ppl in the bg and shadows on the models' faces with over exposed cars can mostly be recovered but why make it hard for ya :yes:
i can show u some examples if ya want?
random cars or ppl in the bg and shadows on the models' faces with over exposed cars can mostly be recovered but why make it hard for ya :D
this is true it was suppose to b overcast that day so didnt really plan for 100% blue skies lol we are going to do another one and will be more concious of what you have said thankyou
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
